Zum Hauptinhalt wechseln
The Ford Explorer and the Mercury Mountaineer were both updated for the 2006 model year on a new frame, produced by Magna International rather than Tower Automotive.
25 Fragen Alle anzeigen
Why rpm jumps during accelaretion between 25mph to 60mph
Hello friends
I have explorer 2009
During idle the rpm is constant
During accelaretion from 0mph to 25mph the engine is smooth
During acceleration from 25mph to 60mph, when I'm in 1500-1400 rpm, it jumps to 1800rpm with rrrrr noise and go down back to 1500rpm.
Its happened several times until I reach 60mph, and then the car drives smoothly.
If I will accelarete with higher rpm, 2000rpm or more, the rpm jumping doesn't accure
What is the cause?
Please help
Thanks
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I'm guessing your descriptions of your xmission is it's downshifting for the jump in rpm. There may be more than one issue here; replacing xmission fluid as recommended in owner's manual, shift linkage adjustment and/or electronics controlling shifts that may need a program update (usually free from manufacturers). I think you can check online if there are any service bulletins related to xmission software updates from the manufacturer.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Guy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 18
Insgesamt: 60
