Zum Hauptinhalt wechseln
16-Bit-Videospielkonsole des japanischen Unternehmens Sega, die 1990 in Europa veröffentlicht wurde.
37 Fragen Alle anzeigen
Why won’t the Genesis turn on?
Hello!
So this question is kind of part of a wild goose chase, but I want to learn so all answers are welcome.
Essentially, I am teaching myself to repair things. I got a Sega Genesis a couple years ago. I had a fancy cord that I could adjust the voltage and polarity on. It got the Genesis running.
To my knowledge, I never fried the console with this cord. However, I wasn’t always able to get my hands on this cable. So I tried others and I can’t power it. Makes me think I potentially fried the board, or maybe I just never found a proper substitute.
So here’s the question.
Assuming the problem is based in the motherboard, what could be the issue? The capacitors did need to be replaced but that is all I remember being an issue.
I’m learning to solder so I’m up for a challenge.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@jakesrepair the main concern I have is that you are using some sort of universal power supply. It is of absolutely vital importance that you ensure that you are using the right voltage and the right polarity. The Genesis Mod. 1 use a reversed polarity power supply. The barrel on the outside is positive and the center pin is negative. Anything else can cause a major issue.
You want to check all the diodes, bridge rectifier and replace all electrolytic capacitors. Clean your board properly and check for corrosion. Ultrasonic cleaning would be the best, but if you do not have that available, it is okay to clean with a high concentrate isopropyl alcohol (97%+) and a soft brush. Check on something like this guide Repairing iPhone Liquid Damage - iFixit Repair Guide for the cleaning. Even so it was written for an Apple iPhone, the principle is identical to your Genesis.
Here are the schematics that might be helpful getting it back to better than new condition Sega Genesis Schematic Diagrams
If you are stuck with anything or have questions regarding components etc. on the board, use this guide Adding images to an existing question - iFixit Repair Guide to add images to your question. That way we can see what you see.
iPhone Bild
Anleitung
iPhone Wasserschaden reparieren
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
iFixit Bild
Anleitung
Bilder zu einer vorhandenen Frage hinzufügen
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Jake Allen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 55
