Zum Hauptinhalt wechseln
Die vierte Generation des Fairphone, hergestellt vom sozialen Unternehmen gleichen Namens. Durchgeführt im Oktober 2021.
16 Fragen Alle anzeigen
Why can't I extract the display?
Approximately two months ago, I accidentally partially destroyed the display of my Fairphone 4, and after various struggles in terms of buying and selling, today I finally managed to get a replacement ready to be installed.
I prepared myself and started the official video available on YouTube. Fully charged battery, screw container, cloth, plastic card, and screwdriver at hand. Everything is ready.
So, I begin, initially struggling a bit with the trickier screws, but soon I find the method. However, it doesn't seem to be enough because when I try to remove the screen, even though all eight screws have been removed, the bottom part, below the SIM slot, remains firmly in place.
And that's the story of how all the waiting has been wasted so far.
I also tried to disassemble the rest, but the bottom part, secured with six silver screws, even after removal, doesn't alleviate my difficulty, while the side part has hexagonal screws, so a crosshead screwdriver doesn't seem to be enough. Now I have reassembled everything except for the eight screws attached to the screen, to see if someone responds today.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
The video I'm referring to is this one:
https://youtu.be/SUJERxuYGLI?si=JA-kqw6M...
von
Einen Kommentar hinzufügen
2 Antworten
@carmelo40109 we are not sure what video you are following. I would have suggest that you use the guide from here Fairphone 4 Display tauschen Going by that, all you should need is a Phillips #00 screwdriver. Post some pictures of what display you have and of the screws etc. that are giving you trouble.
Bilder zu einer vorhandenen Frage hinzufügen
iFixit Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
Fairphone 4 Display Bild
Anleitung
Schwierigkeitsgrad:
Leicht
10 - 20 minutes
War diese Antwort hilfreich?
Bewertung 0
I finally solved it:
all I had to do was to apply more force when extracting the body at the bottom.
I followed the procedure and everything went as planned.
Whoever has the opportunity can now close the topic.
Bewertung 0
Antwort hinzufügen
Carmelo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 12
Letzte 30 Tage: 24
Insgesamt: 146
