Zum Hauptinhalt wechseln
Sony’s 18.2 megapixel camera meant for general photo taking, 3D images, and filming. Model number: DSC-WX100.
7 Fragen Alle anzeigen
Display zeigt "Blitz Lädt nicht"
Hallo.
Kann mir jemand beantworten, wie ich den Blitz reparieren kann?
Kamera funktioniert einwandfrei, jedoch wird im Display seit kurzem E:91:01 "Blitz lädt nicht" angezeigt - egal bei welcher Szeneneinstellung.
Freue mich auf Antworten.
Viele Grüße, Michael
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@michaelhag13663 The E:91:01 flash error affects many Sony models and it is possible that this is a Flash error. So let's start with what Sony recommends
The E:91:01 error code can be due to a flash or battery problem..
Try turning the camera off & then remove the battery..
Leave the battery out of the camera for about 60 seconds..
Then replace the battery and turn on the camera..
If after following the above you still see the error code then all I can suggest is that you contact Sony to arrange a repair.
Of course they would because they do not want you to fix your own camera :-) They like your money (no matter if it is Euros, Pound or Deutsche Mark). Anyhow, besides their nonsense, the error may actually be a false flag in the firmware and bricks your camera. Give this a try first. It should reset and initialize your camera.
If you can get to your menu go to HOME select SETTINGS and select INITIALIZE. Otherwise try this:
-Turn OFF the camera
-Remove the battery or the power supply
-Turn the switch to CAMERA for about 30 sec
-Turn the switch to OFF
-Install the battery or power supply
-Turn the switch to MEMORY
-Open the LCD cover and press the RESET button ( small inner button )
-You will be prompt to adjust date/time. Go ahead and do that
-Take some pictures
The only other things I can offer, if you have to actually work on your camera, are the proper manuals Here is the one that addresses the disassembly etc. and here is the one that deals with the wiring and circuitry. They are in English (mostly :-) but I do hope they will still help you out.
If you have to you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@michaelhag13663 Der Blitzfehler E:91:01 betrifft viele Sony-Modelle und es ist möglich, dass es sich um einen Blitzfehler handelt. Beginnen wir also mit dem, was Sony empfiehlt
Der Fehlercode E:91:01 kann auf ein Problem mit dem Blitz oder der Batterie zurückzuführen sein.
Versuchen Sie, die Kamera auszuschalten und dann den Akku zu entfernen.
Lassen Sie den Akku für etwa 60 Sekunden aus der Kamera.
Setzen Sie dann den Akku wieder ein und schalten Sie die Kamera ein.
Wenn Sie nach den oben genannten Schritten immer noch den Fehlercode sehen, kann ich Ihnen nur raten, Sony zu kontaktieren, um eine Reparatur zu vereinbaren.
Natürlich würden sie das sagen, denn sie wollen nicht, dass Du Deine Kamera selbst reparierst :-) Sie wollen Dein Geld (egal ob es Euros, Pfund oder D-Mark sind).
Wie auch immer, abgesehen von deren Unsinn, könnte der Fehler tatsächlich eine falsche Flagge in der Firmware sein und Deine Kamera blocken. Versuche es zuerst hiermit. Es sollte Deine Kamera zurücksetzen und initialisieren.
Wenn du auf dein Menü zugreifen kannst, gehe zu HOME, wähle SETTINGS und wähle INITIALIZE. Andernfalls versuche dies:
-Schalte die Kamera AUS
-Entnahme der Batterie oder des Netzteils
-Schalte den Schalter ca. 30 Sekunden lang auf CAMERA
-Schalte den Schalter auf OFF
-Setze den Akku oder das Netzteil ein.
-Schalte den Schalter auf MEMORY
-Öffne die LCD-Abdeckung und drücke die RESET-Taste ( kleine innere Taste )
-Du wirst aufgefordert, Datum/Uhrzeit einzustellen. Tue das
-Mach ein paar Fotos
Die einzigen anderen Dinge, die ich dir anbieten kann, wenn du tatsächlich an deiner Kamera arbeiten musst, sind die richtigen Handbücher. Hier ist dasjenige, das sich mit der Demontage usw. befasst Sony DSC WX100 Level 2 und hier ist dasjenige, das sich mit der Verdrahtung und den Schaltkreisen beschäftigt Sony DSC WX100 Level 3. Sie sind auf Englisch (meistens :-), aber ich hoffe, sie Dir trotzdem weiter helfen.
Wenn Du and deiner Kamera arbeiten musst, mach viele Bilder. Wenn du damit fertig bist, nimm diese Bilder und erstelle eine Anleitung für iFixit. Das wird der nächsten Person helfen, die das gleiche Problem hat wie du. Es ist einfach und macht Spaß, diese Anleitungen zu erstellen. https://ifixit.com/Guide/new Die iFixit-Community wird das zu schätzen wissen.
Reparieren ist Krieg gegen Entropie!
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Michael Hagenrainer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 60
