Zum Hauptinhalt wechseln
{A1989 / EMC3214}—Erschienen im Juli 2018. Das 13" MacBook Pro ist mit Quad-Core i5 und i7 Prozessoren und Intel Iris Plus integrierter Grafik ausgestattet.
204 Fragen Alle anzeigen
space bar key is working
While cleaning, I removed the space key but it accidentally got detached from its hinge. Although the hinge wasn't damaged, I noticed that there was a gap in the key after reattaching it, which required me to press it harder each time to make it work.I opened a space key to clean but it got detached with its hinge the hinge was not damaged but when I attached it back there was a gap in the space key as I had to press it harder to work every time.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Often an Apple Store can pop the Space Bar back on, if the clips are damaged they can also replace the part/S as needed.
I would try them first as it’s often done for free. Going to a good independent Mac repair shop might take a bit of time and unlike the Apple Store who will often do it for the good PR the independent needs the income.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Mukul wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 32
