Zum Hauptinhalt wechseln
Samsung announced the Galaxy Flip 4 range at their "Unpacked" event on August 10, 2022. The new series of smartwatches Galaxy Watch 5 and Watch 5 Pro and the new series of Galay Buds 2 Pro were also announced.
20 Fragen Alle anzeigen
Why my phone works only when pluged in charge, and off when unpluged
my phone works when i plug it into the charger but if i unplug it emmediatelly switch off.
it looks as if i am using a laptop with no battery in it, to use the laptop i always have to plug the charger otherwise it shuts down.
thanks, inadvance
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
thanks, when i plug it it starts charging
(shows the circle with 85%) when i switch it on it works, i can use it as ussual, unles i try to unplug it.
yes i have been using it almost for a year.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It sounds like it could be a battery issue, but on a phone this new it seems unlikely that it would fail so quickly. At this point I would be trying to check the charging port first for problems; does it say it's charging when you plug it in?
How long have you had the phone? It should have at least a one year warranty, so it may be worthwhile to check with Samsung as to whether this can be repaired under warranty before you start digging into replacement parts.
War diese Antwort hilfreich?
Bewertung 3
I have a similar issue, but my Z Fold 4's outside screen is not working even when plugged in.
I brought it to Samsung and they are replacing the main board under warrenty.
I'd suggest you to take a backup with Samsung Switch on a PC and head over to Samsung. Not sure where you're from but in the Netherlands we have 2 years of warranty which means this is fully covered.
Bewertung 1
Antwort hinzufügen
peter teklu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 35
Letzte 30 Tage: 186
Insgesamt: 1,290
