LG Dishwasher HE error code. What is this part?
I have an LG LDF5545ST dishwasher. Recently, it started showing an HE error code, indicating a problem with the heating element. I pulled out the dishwasher, turned it over, and removed the bottom cover. The issue is that the connection to the heating element corroded:
I confirmed that the heating element resistance is correct, then soldered a spade terminal onto the wire to verify that it works (it does). I'd now like to make a permanent fix.
The part that is corroded is a small connector with a ceramic base and two spade terminals. The part is easily removed, but isn't identified separately on the parts diagram. Rather it's part of the pump case assembly (Part #ABT72989202). On this dishwasher the heater element cannot be replaced separately from the ($200-$300) pump case assembly.
Since the heater element works, I'd like to replace the electrical connector.
The body of the connector as shown below is 17mm wide, and there should be a spade terminal coming off to the left and right from the main body.
On the back side, I found the following numbers that may or may not be part numbers. I've had no luck finding the part online.
155 131 003 23 16 260C
Any help identifying this part and a place where I can buy it would be appreciated. Thank you!
Ist dies eine gute Frage?
