Zum Hauptinhalt wechseln
Informationen zur Reparatur und Demontage für das ROG Ally, einer tragbare Spielkonsole von ASUS. Veröffentlicht am 13. Juni 2023 und erkennbar an der Modellnummer RC71L.
24 Fragen Alle anzeigen
USB-C port not charging with power delivery
A few days ago, the usb-c port of my ally had stopped charging with the provided adapter. It still connects (a white LED shows up when connected in sleep mode), but it will not charge it, no matter what side of the usb I used.
Right now it only charges with low power cables, the kind that you would use for phones, and (as far as I know) only works on one side of the cable. Obviously it means that I can't use it and charge at the same time, I'd have to wait about 8-9 hours just for it to charge 60%. Non-charging cables work as well, but again only on one side.
I took the ally to two repair shops, both of which did nothing to fix the problem (thinking the adapter was the problem). I think it has to do with the port itself, or somehow a bios update. I hope this could get fixed soon, I don't want have to return it.
Edit: Thanks to JiYoW (@luunfmr2mlkysbv) for helping me out! The solution is to try and switch the "batter care" on the MyAsus app on and off a couple of times, and also the full-charge mode as well just to be safe. Then fully turn off the ally, plug in the charger, and then turn it back on, Very simple!
I'll keep this question open in case the solution doesn't work for someone else, and if others have others ways to fix this (hopefully without going into too many repair shop beforehand 😅)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hey, I know I'm late to the party but I have the same issue as well when it comes to charging the ROG Ally. However, I may have found a fix for this and I have a hunch on how it started on mine. It may be different for both your cases. To determine if my guess is right, before this started, did you turn on the 'Sleep Care' and 'Quick Charge' function on the MyAsus app before this happened? Mine started acting up after doing this. So the solution I had to sort of fixing it is this. I open the MyAsus app, toggle both options a few times and eventually leaving both off before exiting the app. I then shut down the ally. After the complete shut down, I plug in the charger before turning it on and after a few seconds after booting, it charged again. It's still finicky hence me saying that I sort of fixed it. This would mean that it's a software issue on the MyAsus app.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
Hi, upon reading your comment I was intrigued and seeing as though Asus had certified my Rog Ally as e-waste I figured I'd try to see if it is in fact a software issue.
I was able to wipe the intenal drive and reinstall windows 11 and it did in fact seem to fix the issue. What does seem to be causing it (at least when the updates are happening) for me is the AMD display driver as far as I can tell.
Sad to see that Asus are incapable of even basic troubleshooting and repair but there you go.
Process-wise I wiped the drive by using Hiren's Boot CD and then reisnstalled Windows using a new installation USB. I should point out that I had let the battery completely drain as well so I don't know if that played any part in it but there you have it.
von
@ale6is nice! Great to hear that you were able to sort out your issue. I have yet to wipe my device clean and reinstall windows. Might try that at some point just to be sure. %#*@ Asus for letting us have a taste of what handheld pc gaming is only to leave us hanging when it comes to issues like this. I would have thought that they have the knowledge when it comes to this. Turns out, customers are even better at proving support to each other! LOL!
von
omg... IT WORKED! It actually worked!!! thank you so much!
Edit: after some testing, it seems to really work! I'm using a apple high-powered charger, but even though the armory crate said it would not work, it shows as charging in the windows icon. And indeed the percentage does go up, even while gaming. I really can't believe that the solution was this simple the entire time!
von
Honestly goes to show how bad Asus are at troubleshooting their own hardware. Shameful really
von
Hilfreichste Antwort
Hello,
I have the exact same problem and it seems to be in fact an issue with the USB port. Asus are aware of this issue and are refusing to deal with it. I RMA'd my console only to be told it's my fault and that it is "water damaged". They did however offer to sell me a second one for the price of £600 lol. Sorry to say your console is most likely dead until a (realistically probably 3rd party) solution is found.
Bewertung 2
2 Kommentare:
Darn... really?
I'm in the process of getting it to "better" repair shops (as in they claim to fix this type of stuff). But if the issue indeed can't be fixed, I guess I'll either wait until said solution is found, or just sell it for parts...
Either way, thanks for the info, hope things go well for you.👍
von
Thanks, to be honest I've given up on it. I'm more annoyed at Asus' response to this than anything. Suffice it to say I wouldn't want it replaced even if they offered at this point.
From my estimation, and looking at many, many reports saying that the Ally has a lot of issues with not charging and such as ours where the port stops recognising fast charging to be with just the poor build quality of the port itself, and I would honestly hope there is some way to circumvent the USB charging interface, as theoretically one could insert a new charging port between the board and battery, but it would have to be somebody a lot more competent than myself.
Hope you're able to figure something out and fingers crossed some solution is found eventually.
von
Antwort hinzufügen
Kess8a wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 126
Letzte 30 Tage: 587
Insgesamt: 883
