Zum Hauptinhalt wechseln
Repair information for the Raspberry Pi 3 Model B. Released in Febuary of 2016. Model: B.
4 Fragen Alle anzeigen
Raspberry Pi 3B+: HDMI not working
Hi iFixers. I have a couple of Raspberry Pi 3B+ boards that are fully functional but don't detect and therefore don't show any picture over HDMI. It's not a software bug and the connector is fine. I'd appreciate any hints on what chip controls HDMI output on those boards - maybe I'd be able to replace it
Update (01/29/24)
After spending some time examining things around on the board I believe the fault might be due to the IC pictured below or the components to the right. Does anyone know what those are? Any hints would be greatly appreciated 🙌🏻
Update (01/29/24)
And one more weird detail - on the marked pin I get around 3V on the faulty boards instead of around 1,1V on a healthy one - what might cause this? Is this still that HDMI05-CL02F3 chip?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I wonder if LAN7515 C000 chip that controls USB and Ethernet on the Pi also related to HDMI 🤔. Any ideas would be greatly appreciated
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @insympathy
According to the datasheet the IC only handles USB and Ethernet.
If possible, try tracing the connections back from the HDMI port and see what IC they connect to. Wondering if HDMI is incorporated in the main Broadcom SoC IC
War diese Antwort hilfreich?
Bewertung 2
10 Kommentare:
Hey, thanks for a hint - I already found that too.
Now the question is the following: Pi shows the graphical interface over VNC perfectly well, so my guess would be that graphical core does work. It's something between the SoC and the HDMI port that stops the party :)
von
@insympathy
Don't know Raspberry that well but have you tried this
von
Tried all of that, thanks, but sadly it seems that it definitely is a hardware issue
von
@insympathy
You've probably already got this but perhaps check if there's 5V on pin 18 of the HDMI port
von
You are absolutely right and I do get at least 4,7V on pin 18 :)
von
5 weitere Kommentare anzeigen
Antwort hinzufügen
in_sympathy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 26
Insgesamt: 155
