Am I testing continuity correctly?
I recently bought a ifixit multimeter and I tested it out to see if it was working properly. I tried out the different modes and they worked until i tried out continuity. I took a battery that i knew was charged and tried to test it out my multimeter. I turned continuity testing mode on and touched both probes together to see if it would beep and it did. I then took the red probe and held it on positive terminal and put the black probe on negative but the multimeter didnt beep. I was very confused. I then got the idea to put the red probe on the negative terminal and the black probe on the positive terminal and guess what, it beeped.
My question is when testing continuity in a battery am i supposed to put red probe to positive and black probe to negative or am i supposed to do red probe to negative and black probe to positive.
Ist dies eine gute Frage?
1 Kommentar
@jatur6343 think about this for a second. If you have continuity between the + and the - connections, what do you get? A short circuit, right. You would measure continuity on something like a fuse or a switch, with the power off. A fuse would need to give you continuity,if it does not it has blown and thus does not show continuity. A switch shows you continuity if it is turned on, none if it is off. Always make sure that the circuit is unpowered. Like my esteemed colleague already mentioned, you do not measure continuity on a live circuit across the voltage rails. That is a sure fire wire to either damage your meter and/or damage the circuit.
von oldturkey03
