Zum Hauptinhalt wechseln
Informationen zur Reparatur, Demontage und Fehlerbehebung für Apples "kleineres" Flaggschiff-Smartphone 2023, das am 22. September herauskam. Es verfügt über ein 6,1 Zoll ProMotion OLED-Display, ein 3-Linsen-Rückkamerasystem und 5G. Nachfolger des iPhone 14 Pro.
6 Fragen Alle anzeigen
What size screwdrivers do I need to completely tear down an iPhone?
Hi iFixit,
I need to know what screwdrivers to completely tear down and gut a newer iPhone. I know they need Pentalobe and Tri-Wing, but can somebody explain all of the screwdrivers and sizes that an iPhone uses and give me a link, please?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@andrewtayl13352 it'll be a lot easier of you can tell us what you mean by a "newer iPhone". Let's say you are going to gut an iPhone 15 Pro. You go to the guide for really anything on that phone iPhone 15 Pro Taptic Engine tauschen Take a look at the right-hand side. You will see a window that says " What you need" It is in that window that the tools required to work on this model, are listed. This one calls for a
P2 Pentalobe Screwdriver
Phillips #000 Screwdriver
Tri‑point Y000 Screwdriver
You can check the guides to determine which screwdriver you need. This holds true for all the guides pertaining to the iPhones. BTW, why not just make your live easier and have the right tools for the job available at any time. Something like this kit Mako Driver Kit - 64 Precision Bits will have you covered.
Mako Driver Kit - 64 Precision Bits Bild
Produkt
$39.95
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
For iPhone X and higher, do I need a Pinhead Philips to repair the frame on any of those phones? Thanks.
von
Antwort hinzufügen
Andrew Taylor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 64
