Zum Hauptinhalt wechseln
Repair and disassembly information for Logitech's H800 wireless headset. Supports 2.4GHz & Bluetooth. Released in 2011. Model number: 981-000337.
19 Fragen Alle anzeigen
Can the Off/Bluetooth/Dongle switch be reaired or replaced?
The outer part of the H800's Off/Bluetooth/Dongle switch just shore off. The switch itself still works if I slip something rigid, small and thin into the cavity to flip the switch. Can the switch be reaired or replaced? I've used this H800 for 10 years or more so it's long out of warranty.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
[image|3258295]
Here is a picture of the H800. The switch is in the "Off" position. The smooth surface with raised bump to carch a finger or fingernail is missing, making the H800 much harder to use. Ideally I would like to replace the surface of the switch or replace the whole switch so the H800 works as it has before.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I think that would depend on the kind of damage you are trying to describe. If you provide more information abut the damage for example a picture of it, you are more likely to get a more correct diagnosis
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
[image|3258295]
von
Antwort hinzufügen
Vorlonagent wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 33
