Zum Hauptinhalt wechseln
The Theragun Mini is a handheld percussive massage therapy device that is designed to help soothe sore muscles, reduce tension, and improve overall muscle function.
4 Fragen Alle anzeigen
How do I open the Theragun mini?
Something's loose inside and it's really starting to bug me... When I turn it on it sometimes work but mostly it won't turn on. my hypothesis is that piece is jamming the motor. Can someone help me??
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
did you manage to open the device without breaking it? I can't find the way to do it. If you have any picture or guide that help me, I would highly appreciate it :)
von
Einen Kommentar hinzufügen
3 Antworten
@aidenc it's a pryjob! Take a quick look at this video to get an idea how it is put together.
While you work on your Theragun, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
War diese Antwort hilfreich?
Bewertung 0
Dropped my theragun mini and broke the on/off button, so I had no choice but to crack it open. See photo attached.
Bewertung 0
1 Kommentar:
How did you crack it open?
von
If you suspect a free piece internal to your Theragun mini is causing it to malfunction, you can open the machine by following these steps: Check the guide for guidance, accumulate the essential tools, hit upon and take away any screws preserving the casing, cautiously open the device, take a look at and do away with any unfastened pieces, and reassemble the machine securely. If unsure, contact the producer or an expert for assistance.
Bewertung 0
1 Kommentar:
Hi i would like a help to have a road map to how to open my theragun 1st generation.
von
Antwort hinzufügen
Techn0pr0 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 49
Letzte 30 Tage: 243
Insgesamt: 539
