Zum Hauptinhalt wechseln
Technical specifications and repair procedures for the MSI GeForce RTX 3070 VENTUS 2X OC. Released on September 11, 2021.
1 Fragen Alle anzeigen
GPU Heatsink Thermal Pad Thickness?
Does anyone know the correct thermal pad thicknesses for these cards? I have found conflicting information and haven't been able to find firm answers, since there are so many variants. Even going directly to support, their response doesn't seem accurate to what I found when I removed the heatsink.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If you measured the thickness and accounted for probable compression you should be able to relate that to an available item. Personally, I would attempt to use thermal paste, but there might be a voltage diff across it. I'm not sure why pads are used in place of paste.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jamus wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 42
Insgesamt: 85
