Zum Hauptinhalt wechseln
Reparaturanleitungen und Hilfen für Samsung Fernseher.
2635 Fragen Alle anzeigen
UN60KU6270f not powering on.
@oldturkey03 do these work?
the situation is as follows, the tv had a few led diffusers pop off, so I took it apart and replaced them all. on reassembly the red light will turn on, if I hit the power switch the leds will turn on and off, sometimes the on sound will play sometimes it wont. If the main board is disconnected the leds will remain on. I have swapped out both the main board and the power board and think I might be missing something stupid simple like a ground somewhere.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Make sure that with the new main you change the build code and SN from the old board to the new board, you need a factory repair remote for that. Saying that you have replaced everything I would suggest a new lcd panel. They’re pretty easy to crack when replacing the lights on a Samsung the way they are glued down. Before going that route ensure that power is being fed to the panel from the new power board with a multimeter. GND and a power circuit.
There is a potential your tv is still under warranty and you could reach out to Samsung Care. They would find you an authorized service provider in your area.
War diese Antwort hilfreich?
Bewertung 0
@joemontgome2230 let's go through the information you are giving us:
"on reassembly the red light will turn on" your power board supplies standby voltage. Good
"if I hit the power switch the leds will turn on and off" error on Bklight circuit
"sometimes the on sound will play sometimes it wont" could be caused by the TV going into error protection
"If the main board is disconnected the leds will remain on" SMPS working. It;'s not your power board that is the issue
The original issue were loose diffuser on your LED backlights. You said you replaced them all. Does that mean you replaced all of the backlight strips? We will also need to know if your Power LED light changes. it is important to know what happens after the backlight blinks.
I would also not count out the backlight strips. When you disconnect the main board from the powerboard and your back lights come on, do all of them come on. You will need to have a uniform backlight. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that so we can see what you see.
If everything is checking out perfectly, then the issue is a possible short or failed component on your driver boards. Again, we need to see those. Those are the long skinny boards that connect right to the LCD panel. That could possibly be helped by attempting a Tape-Off.
Bewertung 0
Antwort hinzufügen
Joe Montgomery wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 50
Insgesamt: 72
