Battery
2 Antworten 0 Punkte |
How do I remove the battery? |
Why doesn’t the webcam turn on? |
How do I use Wifi instead of the dial-up or ethernet connection? |
Werkzeuge
Es werden ein paar gängige Werkzeuge verwendet, um an diesem Gerät zu arbeiten. Du wirst nicht jedes Werkzeug für jeden Schritt benötigen.
Troubleshooting
If you are having difficulties with theToshiba Satellite L305D-S5900, try referring to the troubleshooting page.
Background and Identification
The Satellite L305D-S5900 is a Toshiba laptop that generally comes standard with Windows Vista Home Premium 32-bit, webcam, ethernet, dial-up & WLAN connection availability, 3GB RAM, 250GB hard disk drive that runs at 5400RPM, and a 15.4” screen. All of which can vary by computer, but uncustomized ones come with this configuration. Since the laptop varies in size, the weight varies as well but is an average of 6 lbs making it slightly more cumbersome than other laptops.
This laptop was released in 2002 and has since been replaced by newer Toshiba Satellite and other model laptops; however, the Satellite series has been discontinued as of 2016.
