Back Panel
Beliebte Fragen im Forum
Eine Frage stellenEs gibt noch keine Fragen. Stelle du die erste!
Werkzeuge
Es werden ein paar gängige Werkzeuge verwendet, um an diesem Gerät zu arbeiten. Du wirst nicht jedes Werkzeug für jeden Schritt benötigen.
Background
The Wyze Cam V2 model was released in mid-February of 2018 by Wyze Inc. Wyze started up in the Amazon headquarters where all three founders used to work. Their mission was to create a smart home product that would be mass-adopted and could be affordable for the average consumer. The competitor at the time Wyze was releasing similar products at around $200, so they decided to release their first indoor model at $19.99.
Although the camera was released in mid-February, it was not shipped out till early April due to a hardware defect.
The V2 model was released with newer features such as motion tagging, being programmed with Amazon’s Alexa and Google Assistant, and a frame rate of 15 fps versus V1's 10 fps.
Identification
The Wyze Cam is a small, white-cubed-shaped device. It has a retractable stand underneath the camera. In the middle of the device are the motion sensor, night vision camera, and the main camera. To find the device's model number, you can look underneath the base and locate the white sticker for the manufacturer's specific identification.
Technical Specifications
Camera Dimensions:
- 127.5 mm (H) x 60 mm (W) x 60 mm (D),
Camera Weight:
- 8.78 oz (249 g)
Powering Methods:
- Ports: 1 micro USB,
- Power Cable Length: 6 feet (1.8 m)
- Power Adapter Input: 110-240V (AC/DC)
- Power Adapter Output: 5V/2000mA
Mounting Features:
- Base Screw Hole: 1/4″ – 20
CPU:
- 1.5 GHz
Memory:
- 128 Mb
Audio & Video:
- Resolution: 1920 X 1080 (1080p)
- H.264 encoding
- Daytime video: 20 FPS
- Night vision: 15 FPS
- Built-in speaker and microphone
- Class-D power amplifier
Camera:
- Lens: F1.6 aperture, 3.2mm focal length
- Image Sensor: 1/2.9'' CMOS
- Digital zoom: 8x
- Field of View: 120° lens
- View Range: 360° horizontal, 93° vertical
Connectivity Requirements:
- 2.4 GHz Wi-Fi
- 802.11 b/g/n 2.4 GHz (Does not support 5 GHz network)
- Supports WPA and WPA2 protocols
- Upload speed is 1.0 Mbps for SD and 1.5 Mbps for HD
Phone Compatibility:
- Supports iOS 14.0 and Android 7.0 or later
