Zum Hauptinhalt wechseln
Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement
Was du brauchst
  1. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: Schritt 2, Bild 1 von 1
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: Schritt 3, Bild 1 von 2 Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: Schritt 3, Bild 2 von 2
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: Schritt 4, Bild 1 von 3 Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: Schritt 4, Bild 2 von 3 Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: Schritt 4, Bild 3 von 3
    • Locate the ODD/HDD/Memory panel.
    • Remove the 1.9 mm screw located on the ODD/HDD/Memory panel with the Philips #0 screwdriver.
    • Slide the ODD/HDD/Memory panel away from the device to remove it.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 1,363
