Zum Hauptinhalt wechseln
Brightsign 4k Battery Replacement
Was du brauchst
  1. Brightsign 4k Battery Replacement, Outer Shell: Schritt 1, Bild 1 von 3 Brightsign 4k Battery Replacement, Outer Shell: Schritt 1, Bild 2 von 3 Brightsign 4k Battery Replacement, Outer Shell: Schritt 1, Bild 3 von 3
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. Brightsign 4k Battery Replacement: Schritt 2, Bild 1 von 3 Brightsign 4k Battery Replacement: Schritt 2, Bild 2 von 3 Brightsign 4k Battery Replacement: Schritt 2, Bild 3 von 3
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. Brightsign 4k Battery Replacement: Schritt 3, Bild 1 von 3 Brightsign 4k Battery Replacement: Schritt 3, Bild 2 von 3 Brightsign 4k Battery Replacement: Schritt 3, Bild 3 von 3
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. Brightsign 4k Battery Replacement: Schritt 4, Bild 1 von 3 Brightsign 4k Battery Replacement: Schritt 4, Bild 2 von 3 Brightsign 4k Battery Replacement: Schritt 4, Bild 3 von 3
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  5. Brightsign 4k Battery Replacement, Motherboard Removal: Schritt 5, Bild 1 von 2 Brightsign 4k Battery Replacement, Motherboard Removal: Schritt 5, Bild 2 von 2
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  6. Brightsign 4k Battery Replacement: Schritt 6, Bild 1 von 2 Brightsign 4k Battery Replacement: Schritt 6, Bild 2 von 2
    • Lift the motherboard out of the casing.
  7. Brightsign 4k Battery Replacement, Battery: Schritt 7, Bild 1 von 2 Brightsign 4k Battery Replacement, Battery: Schritt 7, Bild 2 von 2
    • Flip the motherboard over.
    • Desolder the two solder joints and remove the melted solder.
    • Beware of over heating the soldering kit will damage the logic board.
  8. Brightsign 4k Battery Replacement: Schritt 8, Bild 1 von 3 Brightsign 4k Battery Replacement: Schritt 8, Bild 2 von 3 Brightsign 4k Battery Replacement: Schritt 8, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Desoldering Pump
    $3.99
    Kaufen
    • Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it).
    • Pull the battery from the motherboard.
Abschluss
Tuong Ngo
85 Reputation
1 Anleitung geschrieben
USF Tampa, Team S17-G6, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G6, Boczar Spring 2018
USFT-BOCZAR-S18S17G6
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 418
