Zum Hauptinhalt wechseln
iRulu AX760 Camera Replacement
Was du brauchst
  1. iRulu AX760 Camera Replacement, Battery: Schritt 1, Bild 1 von 3 iRulu AX760 Camera Replacement, Battery: Schritt 1, Bild 2 von 3 iRulu AX760 Camera Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Camera Replacement: Schritt 2, Bild 1 von 1
    • Open your tablet.
  3. iRulu AX760 Camera Replacement: Schritt 3, Bild 1 von 1
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Camera Replacement: Schritt 4, Bild 1 von 2 iRulu AX760 Camera Replacement: Schritt 4, Bild 2 von 2
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. Wie man Lötverbindungen herstellt und entlötet
  5. iRulu AX760 Camera Replacement: Schritt 5, Bild 1 von 1
    • Remove your old battery and replace it with the new battery.
  6. iRulu AX760 Camera Replacement, Camera: Schritt 6, Bild 1 von 2 iRulu AX760 Camera Replacement, Camera: Schritt 6, Bild 2 von 2
    • Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
  7. iRulu AX760 Camera Replacement: Schritt 7, Bild 1 von 1
    • Pull the digitizer ribbon cables straight out of their sockets.
  8. iRulu AX760 Camera Replacement: Schritt 8, Bild 1 von 1
    • Pull the camera out of the device.
Abschluss
Jamison Kritz
245 Reputation
2 Anleitungen geschrieben
IUPUI, Team S6-G4, Baechle Spring 2018 Mitglied von IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 106
