Zum Hauptinhalt wechseln
Dell Inspiron 17-5749 Optical Drive Replacement
Was du brauchst
  1. Dell Inspiron 17-5749 Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 17-5749 Optical Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Optical Drive Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 17-5749 Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 1 von 3 Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 2 von 3 Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 3 von 3
    • Remove the 5.5mm screw that secures the optical-drive assembly to the computer base
    • Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
  4. Dell Inspiron 17-5749 Optical Drive Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 17-5749 Optical Drive Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 17-5749 Optical Drive Replacement: Schritt 4, Bild 3 von 3
    • This step is only needed if replacing the optical drive.
    • Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly.
    • Remove the optical-drive bracket from the optical-drive assembly.
    • Carefully pull the optical-drive bezel and remove it from the optical drive.
Abschluss
Christopher Tran
1.161 Reputation
12 Anleitungen geschrieben
Washington State, Team S1-G2, Lobnitz Spring 2018 Mitglied von Washington State, Team S1-G2, Lobnitz Spring 2018
WSU-LOBNITZ-S18S1G2
6 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 9
Insgesamt: 140
