Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
This step is only needed if replacing the optical drive. Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly. Remove the optical-drive bracket from the optical-drive assembly.
  • This step is only needed if replacing the optical drive.
  • Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly.
  • Remove the optical-drive bracket from the optical-drive assembly.
  • Carefully pull the optical-drive bezel and remove it from the optical drive.
Hier Übersetzung einfügen
