Zum Hauptinhalt wechseln
Alcatel Pop 4 Plus Motherboard Replacement
Was du brauchst
  1. Alcatel Pop 4 Plus Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Alcatel Pop 4 Plus Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Motherboard Replacement: Schritt 2, Bild 1 von 2 Alcatel Pop 4 Plus Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Motherboard Replacement: Schritt 4, Bild 1 von 2 Alcatel Pop 4 Plus Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 2 Alcatel Pop 4 Plus Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
    • Slide the ribbon cable out of the socket.
  6. Alcatel Pop 4 Plus Motherboard Replacement: Schritt 6, Bild 1 von 2 Alcatel Pop 4 Plus Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Use the flat end of a spudger to disconnect the ribbon cable.
  7. Alcatel Pop 4 Plus Motherboard Replacement: Schritt 7, Bild 1 von 2 Alcatel Pop 4 Plus Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Using the flat end of the spudger to disconnect the ribbon cable.
  8. Alcatel Pop 4 Plus Motherboard Replacement: Schritt 8, Bild 1 von 2 Alcatel Pop 4 Plus Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Using the flat end of the spudger, disconnect the camera from the motherboard.
  9. Alcatel Pop 4 Plus Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Use the flat end of the spudger to pry off the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S20-G6, Passmore Spring 2018 Mitglied von USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Hi
I got my Alcatel Pop 4+ checked and it's Power IC was faulty. How can I replace it
I'm looking for the specific IC used in it if I can get any help regarding it.
NINJA WARRIORS - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 18
Insgesamt: 962
