Zum Hauptinhalt wechseln
Kindle Fire HD 8.9" Midframe Replacement
Was du brauchst
  1. Kindle Fire HD 8.9" Midframe Replacement, Screen: Schritt 1, Bild 1 von 3 Kindle Fire HD 8.9" Midframe Replacement, Screen: Schritt 1, Bild 2 von 3 Kindle Fire HD 8.9" Midframe Replacement, Screen: Schritt 1, Bild 3 von 3
    • Insert a large plastic opening tool next to the Kindle's headphone jack.
    • Make sure the notch on the plastic opening tool is facing the back of the Kindle.
    • Move the plastic opening tool evenly around the Kindle, separating the two halves.
    • Be careful not to completely separate the rear cover. There are two delicate flex cables that connect the display assembly to the motherboard.
  2. Kindle Fire HD 8.9" Midframe Replacement: Schritt 2, Bild 1 von 1
    • Set the Kindle down on the rear case.
    • Holding the display assembly near the camera, carefully open the display assembly up to about 90 degrees from the rear case.
    • These images show the Kindle laying flat. In order to prevent damage to the flex cables, keep the Kindle open at 90 degrees while disconnecting the display assembly.
  3. Kindle Fire HD 8.9" Midframe Replacement: Schritt 3, Bild 1 von 3 Kindle Fire HD 8.9" Midframe Replacement: Schritt 3, Bild 2 von 3 Kindle Fire HD 8.9" Midframe Replacement: Schritt 3, Bild 3 von 3
    • Lift the retaining flap on the ZIF connector of the upper flex cable.
    • Gently pull the cable out of its socket.
    • This flex cable is delicate. Be careful not to crease or bend it while working.
  4. Kindle Fire HD 8.9" Midframe Replacement: Schritt 4, Bild 1 von 1
    • Separate the display assembly from the rest of the device.
    • When reassembling the device, align the two halves of the case before connecting the flex cables.
  5. Kindle Fire HD 8.9" Midframe Replacement, Inner Metal Casing: Schritt 5, Bild 1 von 2 Kindle Fire HD 8.9" Midframe Replacement, Inner Metal Casing: Schritt 5, Bild 2 von 2
    • Remove the following sixteen screws from the metal midframe on the rear of the device:
    • Four 3 mm Phillips screw (located in each corner of the device - noted in red in the diagram)
    • Four 3 mm Phillips screws (surrounding the ports - noted in orange in the diagram)
    • Eight 3 mm Phillips screws (located around the body of the midframe - noted in yellow in the diagram)
  6. Kindle Fire HD 8.9" Midframe Replacement: Schritt 6, Bild 1 von 2 Kindle Fire HD 8.9" Midframe Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove the metal midframe.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ted Park
34 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 5-16, Forte Winter 2013 Mitglied von Cal Poly, Team 5-16, Forte Winter 2013
CPSU-FORTE-W13S5G16
5 Mitglieder
14 Anleitungen geschrieben
2 Kommentare
I suggest not removing the cables (steps 3,4 and 5) because it seems impossible to reconnect them.
Tom Wood - Antwort
Those are ZIF connectors—flip up the locking tab to release the cable, and you can remove/reinsert it freely.
Jeff Suovanen -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 1,823
