Zum Hauptinhalt wechseln
Tara Handle Replacement
  1. Tara Handle Replacement, Handle: Schritt 1, Bild 1 von 1
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Use a Tara tool to loosen the jam nuts on either side of the pump.
    • The bolts do not need to be loosened or removed, only the nuts need to be loosened.
  2. Tara Handle Replacement: Schritt 2, Bild 1 von 3 Tara Handle Replacement: Schritt 2, Bild 2 von 3 Tara Handle Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the lock bolts about half an inch.
    • The bolts do not need to be removed from the base.
  3. Tara Handle Replacement: Schritt 3, Bild 1 von 2 Tara Handle Replacement: Schritt 3, Bild 2 von 2
    • Pull the plastic bushing and handle straight up out of the pump.
    • If the bushing doesn't come up, loosen the lock bolts further.
  4. Tara Handle Replacement: Schritt 4, Bild 1 von 2 Tara Handle Replacement: Schritt 4, Bild 2 von 2
    • Lift up the handle and riser main until the joint between the two is at a comfortable height to work on.
  5. Tara Handle Replacement: Schritt 5, Bild 1 von 3 Tara Handle Replacement: Schritt 5, Bild 2 von 3 Tara Handle Replacement: Schritt 5, Bild 3 von 3
    • Loosen the jam nut beneath the pump handle using the Tara tool.
  6. Tara Handle Replacement: Schritt 6, Bild 1 von 2 Tara Handle Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the pump handle from the top of the riser main.
    • Make sure someone is tightly holding the lower portion of the riser main to prevent losing it down the well.
  7. Tara Handle Replacement: Schritt 7, Bild 1 von 2 Tara Handle Replacement: Schritt 7, Bild 2 von 2
    • Lift and remove the handle from the pump. Store the handle in a sanitary place to prevent contamination.
Abschluss
Sam Goldheart
465.958 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.298 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 218
