Zum Hauptinhalt wechseln
Crosley CR42 Band Replacement
Was du brauchst
  1. Crosley CR42  Band Replacement, Band: Schritt 1, Bild 1 von 1
    • Check troubleshooting wiki to make sure you aren't doing way more work than you have to!
    • If you believe the band may be broken or out of place, start by unplugging the record player.
  2. Crosley CR42  Band Replacement: Schritt 2, Bild 1 von 2 Crosley CR42  Band Replacement: Schritt 2, Bild 2 von 2
    • Make sure the needle is in its resting position off to the side.
    • Gently remove the turntable from the device by lifting it directly upward.
  3. Crosley CR42  Band Replacement: Schritt 3, Bild 1 von 1
    • Find the band, it may have fallen into the inside of the record player as you removed the turntable.
    • Inspect your band for any tears, rips, or obvious signs of stretching.
  4. Crosley CR42  Band Replacement: Schritt 4, Bild 1 von 1
    • Flip the turntable over.
    • Locate the notch on the back side of the turntable.
    • The notch will be on the outside edge of the turntable.
  5. Crosley CR42  Band Replacement: Schritt 5, Bild 1 von 2 Crosley CR42  Band Replacement: Schritt 5, Bild 2 von 2
    • Wrap the band around the inner circle of the turntable and gently pull the band until you get to the notch.
    • Loop the band around the notch, the band should be taut.
  6. Crosley CR42  Band Replacement: Schritt 6, Bild 1 von 2 Crosley CR42  Band Replacement: Schritt 6, Bild 2 von 2
    • Place the turntable back onto the device.
    • Make sure to line up the band with the turning knob, to ensure the band is properly placed.
  7. Crosley CR42  Band Replacement: Schritt 7, Bild 1 von 1
    • After the turntable is back on the device, gently turn it clockwise until you hear a 'click.'
    • Job well done!
Ziellinie
Roberto Rosila
319 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 1-38, Maness Winter 2014 Mitglied von Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
My CR42 has a plastic piece that will not let me simply pull the turntable off. I don't want to try to hard to break it, but I also don't know how to get it off to replace the band.
athena - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 64
Insgesamt: 4,853
