Zum Hauptinhalt wechseln
Atari Lynx Battery Wire Replacement
Was du brauchst
  1. Atari Lynx Battery Wire Replacement, Atari Lynx: Schritt 1, Bild 1 von 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Atari Lynx Battery Wire Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Atari Lynx Battery Wire Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Atari Lynx Battery Wire Replacement: Schritt 4, Bild 1 von 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Atari Lynx Battery Wire Replacement, Battery Wires: Schritt 5, Bild 1 von 1
    • Desolder both the black and red wire as shown.
    • If you need help with basic desoldering, click here.
  6. Atari Lynx Battery Wire Replacement: Schritt 6, Bild 1 von 1
    • Desolder the black wire as shown.
  7. Atari Lynx Battery Wire Replacement: Schritt 7, Bild 1 von 2 Atari Lynx Battery Wire Replacement: Schritt 7, Bild 2 von 2
    • Desolder the white wire and then the red wire as shown.
  8. Atari Lynx Battery Wire Replacement: Schritt 8, Bild 1 von 1
    • Desolder the white wire as shown in order for the battery pack to be completely removed from the device.
Abschluss
John Lopez
443 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 1-42, Maness Winter 2014 Mitglied von Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 35
Insgesamt: 1,742
