Zum Hauptinhalt wechseln
Motorola syn1654A Microphone Replacement
Was du brauchst
  1. Motorola syn1654A Microphone Replacement, Microphone: Schritt 1, Bild 1 von 2 Motorola syn1654A Microphone Replacement, Microphone: Schritt 1, Bild 2 von 2
    • Remove star head screw from above base of the microphone with T6 Torx Screwdriver.
    • To prevent stripping, use an appropriate bit and ensure screwdriver is oriented perpendicular to the face of the screw.
  2. Motorola syn1654A Microphone Replacement: Schritt 2, Bild 1 von 1
    • To expose the next screw, peel foam cover from the base toward the end of microphone.
    • Remove screw with screwdriver and place in a safe location.
  3. Motorola syn1654A Microphone Replacement: Schritt 3, Bild 1 von 3 Motorola syn1654A Microphone Replacement: Schritt 3, Bild 2 von 3 Motorola syn1654A Microphone Replacement: Schritt 3, Bild 3 von 3
    • With Screws removed, remove the microphone from foam and plastic cover to be inspected.
    • If the microphone is corroded or wires are frayed, it must be replaced.
  4. Motorola syn1654A Microphone Replacement: Schritt 4, Bild 1 von 1
    • Clip both wires to remove defective microphone.
    • Be sure to clip as close to the base of the microphone as possible in order to have enough wire for the new microphone.
    • Align wires with corresponding pads on new microphone and solder in place.
    • For soldering, see the Ifixit soldering guide: Wie man Lötverbindungen herstellt und entlötet
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
John Ware
325 Reputation
2 Anleitungen geschrieben
Michigan Tech, Team 5-1, Lauer Spring 2014 Mitglied von Michigan Tech, Team 5-1, Lauer Spring 2014
MTU-LAUER-S14S5G1
2 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 9
Insgesamt: 360
