Zum Hauptinhalt wechseln
Dell Latitude E6540 Battery Replacement
Was du brauchst
  1. Dell Latitude E6540 Battery Replacement, Hibernate your laptop: Schritt 1, Bild 1 von 2 Dell Latitude E6540 Battery Replacement, Hibernate your laptop: Schritt 1, Bild 2 von 2
    • It is possible to plug the laptop in to avoid hibernating the system.
    • Locate the Hibernate option in the Start menu. Let the system fully hibernate (or shut down) before removing the battery.
  2. Dell Latitude E6540 Battery Replacement, Unlock the battery: Schritt 2, Bild 1 von 2 Dell Latitude E6540 Battery Replacement, Unlock the battery: Schritt 2, Bild 2 von 2
    • Flip the laptop over and unlock the 2 battery tabs. The tabs will remain unlocked until the battery is removed.
  3. Dell Latitude E6540 Battery Replacement, Remove the old battery: Schritt 3, Bild 1 von 3 Dell Latitude E6540 Battery Replacement, Remove the old battery: Schritt 3, Bild 2 von 3 Dell Latitude E6540 Battery Replacement, Remove the old battery: Schritt 3, Bild 3 von 3
    • The "extended runtime" battery on this model will stick out a few inches by design. This cannot be avoided.
    • Remove the battery. Pull the battery up from the back.
  4. Dell Latitude E6540 Battery Replacement, Install the new battery: Schritt 4, Bild 1 von 3 Dell Latitude E6540 Battery Replacement, Install the new battery: Schritt 4, Bild 2 von 3 Dell Latitude E6540 Battery Replacement, Install the new battery: Schritt 4, Bild 3 von 3
    • This step does not apply if this guide is being used as a prerequisite.
    • Align the battery with the tabs on the chassis. Drop the battery in place once lined up. If needed, use light pressure to seat it in the computer.
  5. Dell Latitude E6540 Battery Replacement, Plug your laptop in: Schritt 5, Bild 1 von 1
    • Turn the computer on and plug the charger in.
Ziellinie
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Nick
88.987 Reputation
50 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.466 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 45
Insgesamt: 8,175
