Zum Hauptinhalt wechseln
Sony PS1100 Needle Cartridge Replacement
  1. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: Schritt 1, Bild 1 von 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: Schritt 1, Bild 2 von 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: Schritt 1, Bild 3 von 3
    • Place the Arm of the record player into the latch to ensure that it does not move during the needle replacement.
    • The arm must be fully locked into place
  2. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge: Schritt 2, Bild 1 von 1
    • Firmly grip both sides of the cartridge with your thumb and index fingers.
    • CAREFULLY pull the entire cartridge so that it slides out towards the front of the arm holding the needle.
  3. Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: Schritt 3, Bild 1 von 2 Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: Schritt 3, Bild 2 von 2
    • Using the New cartridge (Sony VL-30G) gently slide into the arm of the record player. It will click into place when inserted properly.
    • Be careful not to touch the needle when inserting the cartridge or else you risk breaking the new one.
  4. Sony PS1100 Needle Cartridge Replacement, Test the new needle Cartridge: Schritt 4, Bild 1 von 1
    • Once the needle clicks into place, test the record player to ensure that the needle works properly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
L Cis
110 Reputation
1 Anleitung geschrieben
USF Tampa, Team 1-8, Donnelly Fall 2014 Mitglied von USF Tampa, Team 1-8, Donnelly Fall 2014
USFT-DONNELLY-F14S1G8
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 37
Insgesamt: 4,635
