Zum Hauptinhalt wechseln
Nvidia Shield Battery Assembly Replacement
Was du brauchst
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: Schritt 1, Bild 1 von 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: Schritt 1, Bild 2 von 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: Schritt 1, Bild 3 von 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: Schritt 2, Bild 1 von 2 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: Schritt 2, Bild 2 von 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: Schritt 3, Bild 1 von 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: Schritt 3, Bild 2 von 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: Schritt 3, Bild 3 von 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: Schritt 4, Bild 1 von 1
    • Pull the battery apparatus out once all cables are removed.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 1-1, Hickman Fall 2014 Mitglied von USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Mitglieder
18 Anleitungen geschrieben
4 Kommentare
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Antwort
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - Antwort
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - Antwort
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 24
Letzte 30 Tage: 54
Insgesamt: 6,043
