Zum Hauptinhalt wechseln
Sony FDL-220R Watchman Battery and Battery Contacts Replacement
Was du brauchst
  1. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: Schritt 1, Bild 1 von 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: Schritt 1, Bild 2 von 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts in battery compartment: Schritt 2, Bild 1 von 1
    • Inspect battery contacts for any signs of damage.
    • Clean battery contacts with a solution of warm water and baking soda if there is corrosion.
  3. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: Schritt 3, Bild 1 von 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: Schritt 3, Bild 2 von 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  4. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: Schritt 4, Bild 1 von 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: Schritt 4, Bild 2 von 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  5. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts on inside of back cover: Schritt 5, Bild 1 von 1
    • Inspect the two small springs on the back of the battery compartment.
    • Clean contacts with a solution of warm water and baking soda if there is corrosion.
Abschluss
Sam Putnam
484 Reputation
4 Anleitungen geschrieben
Baylor, Team 4-5, Williams Fall 2014 Mitglied von Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 496
