Zum Hauptinhalt wechseln
GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement
Was du brauchst
  1. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery Compartment Cover: Schritt 1, Bild 1 von 3 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery Compartment Cover: Schritt 1, Bild 2 von 3 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery Compartment Cover: Schritt 1, Bild 3 von 3
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery: Schritt 2, Bild 1 von 2 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery: Schritt 2, Bild 2 von 2
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Screws: Schritt 3, Bild 1 von 2 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Screws: Schritt 3, Bild 2 von 2
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, LCD Cover: Schritt 4, Bild 1 von 1
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Clock Radio: Schritt 5, Bild 1 von 2 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Clock Radio: Schritt 5, Bild 2 von 2
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
  6. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery Wires Wire Tie: Schritt 6, Bild 1 von 2 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Battery Wires Wire Tie: Schritt 6, Bild 2 von 2
    • Using the wire cutters, carefully cut the plastic wire tie.
  7. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Speaker: Schritt 7, Bild 1 von 1
    • Grip the speaker.
    • Lift the speaker from the holder.
  8. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Screws: Schritt 8, Bild 1 von 2 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, Screws: Schritt 8, Bild 2 von 2
    • Locate the two 6mm screws on the PCB.
    • Using a Phillips #0 Screwdriver, unscrew the two 6 mm screws from the PCB.
  9. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, AM-FM Switch Dial Screw: Schritt 9, Bild 1 von 2 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, AM-FM Switch Dial Screw: Schritt 9, Bild 2 von 2
    • Raise the PCB to expose the AM-FM switch dial screw.
    • Using a Phillip's #01 Screwdriver, unscrew the one 3mm screw from the middle of the AM-FM switch dial.
  10. GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, AM-FM Pins: Schritt 10, Bild 1 von 3 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, AM-FM Pins: Schritt 10, Bild 2 von 3 GE 7-4836B Alarm Clock AM-FM Radio AM-FM Switch Replacement, AM-FM Pins: Schritt 10, Bild 3 von 3
    • Locate the AM-FM pins on the PCB.
    • Carefully apply the hot soldering iron to the solder on top of the AM-FM pins.
    • Gently and firmly push on the pins with the Spudger to remove the switch from the underside of the PCB.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 1,072
