Zum Hauptinhalt wechseln
Samsung Galaxy S4 Active SIM Card Replacement
Was du brauchst
  1. Samsung Galaxy S4 Active SIM Card Replacement, Rear Case: Schritt 1, Bild 1 von 2 Samsung Galaxy S4 Active SIM Card Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active SIM Card Replacement, Battery: Schritt 2, Bild 1 von 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  3. Samsung Galaxy S4 Active SIM Card Replacement, SIM Card: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the SIM card.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Geoff Wacker
89.956 Reputation
89 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 3,804
