Zum Hauptinhalt wechseln
Polaroid PTAB7XC Battery Replacement
Was du brauchst
  1. Polaroid PTAB7XC Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Polaroid PTAB7XC Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver, turning them counterclockwise.
    • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
  2. Polaroid PTAB7XC Battery Replacement: Schritt 2, Bild 1 von 3 Polaroid PTAB7XC Battery Replacement: Schritt 2, Bild 2 von 3 Polaroid PTAB7XC Battery Replacement: Schritt 2, Bild 3 von 3
    • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
    • Lift the device off of the case and flip over the device so that it sits screen side down.
    • The device is now free from the plastic casing.
    • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
  3. Polaroid PTAB7XC Battery Replacement: Schritt 3, Bild 1 von 2 Polaroid PTAB7XC Battery Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Wedge a plastic card beneath the battery unit.
    • Wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
    • Do not rupture the battery; it poses a serious safety hazard.
    • There is a plastic bag around the battery; if torn or stretched, there is no safety hazard.
  4. Polaroid PTAB7XC Battery Replacement: Schritt 4, Bild 1 von 3 Polaroid PTAB7XC Battery Replacement: Schritt 4, Bild 2 von 3 Polaroid PTAB7XC Battery Replacement: Schritt 4, Bild 3 von 3
    • Set the device on a heat safe surface.
    • Desolder from the motherboard the red wire that connects to the battery unit.
    • Desolder from the motherboard the black wire that connects to the battery unit.
    • Lift the battery out of the device using your hands.
    • The battery is now free from the device.
    • If either of the wires do not come completely free when desoldering, use tweezers to gently pull them free.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
This tablet has the exact same setup as the 2011-2012 nextbook part might be interchangeable with this tablet .
Walker wallace - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 12
Insgesamt: 2,081
