Zum Hauptinhalt wechseln
HP Pavilion zd8000 Switch Cover Replacement
Was du brauchst
  1. HP Pavilion zd8000 Switch Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Switch Cover Replacement: Schritt 2, Bild 1 von 2 HP Pavilion zd8000 Switch Cover Replacement: Schritt 2, Bild 2 von 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: Schritt 3, Bild 1 von 2 HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: Schritt 3, Bild 2 von 2
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  4. HP Pavilion zd8000 Switch Cover Replacement: Schritt 4, Bild 1 von 2 HP Pavilion zd8000 Switch Cover Replacement: Schritt 4, Bild 2 von 2
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  5. HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: Schritt 5, Bild 1 von 2 HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: Schritt 5, Bild 2 von 2
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  6. HP Pavilion zd8000 Switch Cover Replacement: Schritt 6, Bild 1 von 1
    • Flip the laptop over.
    • Fully open the laptop.
  7. HP Pavilion zd8000 Switch Cover Replacement: Schritt 7, Bild 1 von 3 HP Pavilion zd8000 Switch Cover Replacement: Schritt 7, Bild 2 von 3 HP Pavilion zd8000 Switch Cover Replacement: Schritt 7, Bild 3 von 3
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Allie Menard
820 Reputation
13 Anleitungen geschrieben
Cal Poly, Team 24-56, Amido Spring 2011 Mitglied von Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 2,100
