Zum Hauptinhalt wechseln
Lighting: Replacing Light Emitting Diode
Was du brauchst
  1. Lighting: Replacing Light Emitting Diode, Light Emitting Diode: Schritt 1, Bild 1 von 1
    • Using a plastic opening tool, remove the base of the Light Angel.
    • Insert the plastic opening tool between the base and the LED housing and pull outwards on the handle.
  2. Lighting: Replacing Light Emitting Diode: Schritt 2, Bild 1 von 1
    • Using a Phillips head jeweler's screwdriver, remove the screw on the battery housing.
    • To remove the screw, turn counterclockwise.
    • Remember to put all the screws you take out somewhere safe so you can find them when it's time to reassemble the light.
  3. Lighting: Replacing Light Emitting Diode: Schritt 3, Bild 1 von 1
    • Remove and set aside the (4) AA batteries in the battery housing.
  4. Lighting: Replacing Light Emitting Diode: Schritt 4, Bild 1 von 1
    • Using a Phillips head jeweler's screwdriver, remove the (6) screws holding the LED housing together.
    • To remove the screws, turn counterclockwise.
  5. Lighting: Replacing Light Emitting Diode: Schritt 5, Bild 1 von 1
    • Insert the plastic opening tool into the crease on the side of the LED housing to separate it from the rest of the device.
  6. Lighting: Replacing Light Emitting Diode: Schritt 6, Bild 1 von 1
    • Locate the faulty light emitting diode on the back of the circuit board.
    • Using a soldering iron and desoldering braid, unsolder the connection on the light emitting diode.
    • Do not allow the soldering iron to come in contact with other components on the circuit board.
    • For detailed instructions on how to solder go to Wie man Lötverbindungen herstellt und entlötet
  7. Lighting: Replacing Light Emitting Diode: Schritt 7, Bild 1 von 1
    • Insert the new light emitting diode through the two holes left from removing the old one.
    • Note: the picture is not of the Light Angel circuit board. It is a general example of inserting a light emitting diode on a circuit board. Photo Credit: Wie man Lötverbindungen herstellt und entlötet
  8. Lighting: Replacing Light Emitting Diode: Schritt 8, Bild 1 von 1
    • Using solder and a soldering iron, solder the new LED to the circuit board.
    • Keep your solder joints separate to avoid short circuiting the circuit board.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Colorado Springs, Team 8-6, Mcmichael Spring 2016 Mitglied von Colorado Springs, Team 8-6, Mcmichael Spring 2016
UCCS-MCMICHAEL-S16S8G6
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 77
Insgesamt: 4,673
