Zum Hauptinhalt wechseln
How to troubleshoot and fix a Xbox 360 DVD drive
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. How to troubleshoot and fix a Xbox 360 DVD drive, Hard Drive: Schritt 1, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive, Hard Drive: Schritt 1, Bild 2 von 2
    • Grasp the hard drive assembly and press the release button while lifting its front edge.
    • Remove the hard drive assembly from the top vent.
  2. How to troubleshoot and fix a Xbox 360 DVD drive, Bottom Vent: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Xbox 360 Opening Tool
    Kaufen
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
  3. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 3, Bild 1 von 3 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 3, Bild 2 von 3 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 3, Bild 3 von 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
  4. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 4, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 4, Bild 2 von 2
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
  5. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 5, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 5, Bild 2 von 2
    • Repeat the same process to release the two center clips on the bottom vent.
  6. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 6, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 6, Bild 2 von 2
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
  7. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 7, Bild 1 von 1
    • Remove the bottom vent from the 360.
  8. How to troubleshoot and fix a Xbox 360 DVD drive, Faceplate: Schritt 8, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive, Faceplate: Schritt 8, Bild 2 von 2
    • Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
    • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
    • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
  9. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 9, Bild 1 von 1
    • Repeat the same motions as previously mentioned to release the left side of the faceplate.
  10. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 10, Bild 1 von 1
    • Remove the faceplate from the front face of the console.
  11. How to troubleshoot and fix a Xbox 360 DVD drive, Top Vent: Schritt 11, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive, Top Vent: Schritt 11, Bild 2 von 2
    • Stand the console vertically with the top edge facing up.
    • The top vent is secured to the console via clips. The first two clips are located underneath the top vent closest to the faceplate, as shown in the pictures.
  12. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 12, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 12, Bild 2 von 2
    • Insert the flat end of a spudger into the small gaps previously mentioned to release the clips.
    • You may also use the long finger of an Xbox 360 opening tool to accomplish this task.
  13. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 13, Bild 1 von 3 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 13, Bild 2 von 3 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 13, Bild 3 von 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the top vent. Their locations are highlighted in red.
  14. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 14, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 14, Bild 2 von 2
    • To release the clips, work from the middle of the top vent.
    • While slightly lifting the front edge of the top vent, use the tip of a spudger to push the clips closest to the center of the top vent towards the inside of the console.
  15. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 15, Bild 1 von 1
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox's upper case.
  16. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 16, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 16, Bild 2 von 2
    • The last clip is hidden underneath the rubber foot nearest the back of the console.
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox.
    • Remove the top vent from the 360.
  17. How to troubleshoot and fix a Xbox 360 DVD drive, Lower Case: Schritt 17, Bild 1 von 1
    • Stand the console vertically with the top edge facing down.
    • Carefully peel the warranty sticker off the console.
  18. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 18, Bild 1 von 3 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 18, Bild 2 von 3 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 18, Bild 3 von 3
    • The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console.
    • Use the flat end of a spudger to release the following latches:
    • Above the front-facing USB ports.
    • Beneath the front-facing USB ports.
    • Above the Memory Unit slots.
  19. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 19, Bild 1 von 1
    • Insert the flat end of a spudger and pry upwards to release the last remaining latch located above the eject button.
  20. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 20, Bild 1 von 1
    • Slightly lift the front portion of the lower case to ensure that the latches in the front have been completely released.
  21. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 21, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 21, Bild 2 von 2
    • The upper and lower cases are held together by seven release latches located on the back of the console. Their locations are highlighted in red.
  22. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 22, Bild 1 von 3 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 22, Bild 2 von 3 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 22, Bild 3 von 3
    • Press the Xbox 360 opening tool down into the clips securing the lower case to the upper case near the I/O ports.
    • While pressing down on the tool, push the lower and upper cases apart to separate the retaining clips.
  23. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 23, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 23, Bild 2 von 2
    • While pushing the upper and lower cases apart, use the tip of a spudger or the finger of an Xbox 360 opening tool to push the long clip highlighted in red toward the center of the 360.
    • The clip should release, leaving the clips near the power connector as the only thing holding the upper and lower cases together.
  24. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 24, Bild 1 von 1
    • Press the Xbox 360 opening tool down into the two remaining clips near the power connector.
    • Push the upper and lower cases apart to fully release the retaining clips.
  25. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 25, Bild 1 von 1
    • Orient the console so that the front portion is facing downwards.
    • Grasp the back portion of the lower case and lift it upwards to separate it from the console.
    • Be careful not to excessively bend the lower case near the power plug, as it can crack easily.
  26. How to troubleshoot and fix a Xbox 360 DVD drive, Eject Button: Schritt 26, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive, Eject Button: Schritt 26, Bild 2 von 2
    • Use the tip of a spudger to release the clip securing the eject button to the metal casing.
    • Insert the flat end of a spudger between the eject button and the optical drive.
    • Pry the eject button off its retaining posts and remove it from the 360.
    • This can also be accomplished using an Xbox 360 opening tool.
  27. How to troubleshoot and fix a Xbox 360 DVD drive, Upper Case: Schritt 27, Bild 1 von 1
    • Remove the six silver 64 mm T10 Torx screws securing the upper case to the metal casing.
  28. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 28, Bild 1 von 1
    • Orient the console so that the upper case is facing upwards.
    • Lift the upper case straight up and remove it from the console.
  29. How to troubleshoot and fix a Xbox 360 DVD drive, Optical Drive: Schritt 29, Bild 1 von 1
    • Peel the silver tape securing the optical drive to the metal casing.
  30. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 30, Bild 1 von 1
    • Slightly lift the optical drive upwards to gain clearance to disconnect the SATA and power connectors located on the backside of the optical drive.
    • Don't try to completely remove the optical drive just yet. Two cables still connect it to the motherboard.
  31. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 31, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 31, Bild 2 von 2
    • Grab the power connector by its cables and pull it straight out of its socket on the optical drive.
    • Disconnect the SATA data connector from its socket on the optical drive by pulling it straight away.
  32. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 32, Bild 1 von 1
    • Lift the optical drive assembly out of the metal casing.
  33. How to troubleshoot and fix a Xbox 360 DVD drive, Xbox 360 Optical Drive Replacement: Schritt 33, Bild 1 von 2 How to troubleshoot and fix a Xbox 360 DVD drive, Xbox 360 Optical Drive Replacement: Schritt 33, Bild 2 von 2
    • While pressing the optical drive cover toward the top face of the optical drive, use the flat end of a spudger to release the two retaining clips on the underside of the cover.
  34. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 34, Bild 1 von 1
    • Remove the optical drive cover.
    • Optical drive remains.
  35. How to troubleshoot and fix a Xbox 360 DVD drive, How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 35, Bild 1 von 1
    • One of the easiest ways to replace your DVD Drive is to swap out the circuit board from your faulty drive into a new drive. However, you need to make sure that you use exactly the same model of DVD Drive as the one you own. The key is kept on a chip on this board we are swapping, so as far as the Xbox is concerned nothing has changed.
  36. How to troubleshoot and fix a Xbox 360 DVD drive: Schritt 36, Bild 1 von 1
    • This is a simple procedure for the Hitachi and Samsung/Toshiba Drives (you only need to disconnect two ribbon cables and then reattach them) in the BenQ drive you need to de-solder and resolder 9 wires too.
Abschluss
18 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Thank you. That helped me a lot.
Laurelinwen - Antwort
just a quick question about the Phillips LiteOn does this only have the ribbon cables or is there desoldering and soldering needed. Thanks
Rick - Antwort
Its needs to be desoldered
Waldo Salazar -
For those of us who are a bit inferior, is there any "alternative" parts one could use to fix the eject problem on DVD-Drive? Like the rubber parts? Maybe a small rubber band with strong resistance? TIA.
Chris Fisher - Antwort
Please help, i need to readjust the height of the guide rails on the sides of the laser, the long silver rods that the laser asembley moves on, i need to get those screws back to factory height, And Its not the pots that need readjustment
James Balsley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 13
Insgesamt: 22,039
