Zum Hauptinhalt wechseln
Dell Inspiron 1525 Heat Sink Replacement
Was du brauchst
  1. Dell Inspiron 1525 Heat Sink Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Heat Sink Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 1525 Heat Sink Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: Schritt 3, Bild 1 von 2 Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: Schritt 3, Bild 2 von 2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: Schritt 4, Bild 1 von 3 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: Schritt 4, Bild 2 von 3 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: Schritt 4, Bild 3 von 3
    • Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
    • These screws are attached to the heat sink assembly.
    • Gently lift the heat sink from side indicated in the picture.
    • The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
    • Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 7,861
