Zum Hauptinhalt wechseln
PlayStation Vita Camera Replacement
Was du brauchst
  1. PlayStation Vita Camera Replacement, Case Separation: Schritt 1, Bild 1 von 2 PlayStation Vita Camera Replacement, Case Separation: Schritt 1, Bild 2 von 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Camera Replacement: Schritt 2, Bild 1 von 3 PlayStation Vita Camera Replacement: Schritt 2, Bild 2 von 3 PlayStation Vita Camera Replacement: Schritt 2, Bild 3 von 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Camera Replacement: Schritt 3, Bild 1 von 2 PlayStation Vita Camera Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Camera Replacement: Schritt 4, Bild 1 von 3 PlayStation Vita Camera Replacement: Schritt 4, Bild 2 von 3 PlayStation Vita Camera Replacement: Schritt 4, Bild 3 von 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Camera Replacement: Schritt 5, Bild 1 von 2 PlayStation Vita Camera Replacement: Schritt 5, Bild 2 von 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Camera Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Camera Replacement: Schritt 7, Bild 1 von 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Camera Replacement: Schritt 8, Bild 1 von 1
    • Separate the front and rear cases.
  9. PlayStation Vita Camera Replacement, Camera: Schritt 9, Bild 1 von 2 PlayStation Vita Camera Replacement, Camera: Schritt 9, Bild 2 von 2
    • Release the camera flex cable socket by prying up on the tab with a spudger. Leave the socket open.
  10. PlayStation Vita Camera Replacement: Schritt 10, Bild 1 von 3 PlayStation Vita Camera Replacement: Schritt 10, Bild 2 von 3 PlayStation Vita Camera Replacement: Schritt 10, Bild 3 von 3
    • Using a spudger, gently pry up the camera.
    • Work your way under the camera and along the camera flex cable, using the pointy tip of the spudger to peel away the adhesive, freeing the camera.
    • Carefully lift and remove the camera.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Brittany McCrigler
89.020 Reputation
131 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.243 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 22
Letzte 30 Tage: 88
Insgesamt: 8,685
