Zum Hauptinhalt wechseln
PlayStation Vita Start/Select Button Replacement
Was du brauchst
  1. PlayStation Vita Start/Select Button Replacement, Case Separation: Schritt 1, Bild 1 von 2 PlayStation Vita Start/Select Button Replacement, Case Separation: Schritt 1, Bild 2 von 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Start/Select Button Replacement: Schritt 2, Bild 1 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 2, Bild 2 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 2, Bild 3 von 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Start/Select Button Replacement: Schritt 3, Bild 1 von 2 PlayStation Vita Start/Select Button Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Start/Select Button Replacement: Schritt 4, Bild 1 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 4, Bild 2 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 4, Bild 3 von 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Start/Select Button Replacement: Schritt 5, Bild 1 von 2 PlayStation Vita Start/Select Button Replacement: Schritt 5, Bild 2 von 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Start/Select Button Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Start/Select Button Replacement: Schritt 7, Bild 1 von 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Start/Select Button Replacement: Schritt 8, Bild 1 von 1
    • Separate the front and rear cases.
  9. PlayStation Vita Start/Select Button Replacement, Wireless Card: Schritt 9, Bild 1 von 3 PlayStation Vita Start/Select Button Replacement, Wireless Card: Schritt 9, Bild 2 von 3 PlayStation Vita Start/Select Button Replacement, Wireless Card: Schritt 9, Bild 3 von 3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Start/Select Button Replacement: Schritt 10, Bild 1 von 2 PlayStation Vita Start/Select Button Replacement: Schritt 10, Bild 2 von 2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Start/Select Button Replacement: Schritt 11, Bild 1 von 2 PlayStation Vita Start/Select Button Replacement: Schritt 11, Bild 2 von 2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Start/Select Button Replacement, Right Shoulder Button: Schritt 12, Bild 1 von 3 PlayStation Vita Start/Select Button Replacement, Right Shoulder Button: Schritt 12, Bild 2 von 3 PlayStation Vita Start/Select Button Replacement, Right Shoulder Button: Schritt 12, Bild 3 von 3
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Start/Select Button Replacement: Schritt 13, Bild 1 von 1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Start/Select Button Replacement: Schritt 14, Bild 1 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 14, Bild 2 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 14, Bild 3 von 3
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Start/Select Button Replacement: Schritt 15, Bild 1 von 2 PlayStation Vita Start/Select Button Replacement: Schritt 15, Bild 2 von 2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Start/Select Button Replacement, Right Button Board: Schritt 16, Bild 1 von 2 PlayStation Vita Start/Select Button Replacement, Right Button Board: Schritt 16, Bild 2 von 2
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Start/Select Button Replacement: Schritt 17, Bild 1 von 2 PlayStation Vita Start/Select Button Replacement: Schritt 17, Bild 2 von 2
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Start/Select Button Replacement: Schritt 18, Bild 1 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 18, Bild 2 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 18, Bild 3 von 3
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Start/Select Button Replacement: Schritt 19, Bild 1 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 19, Bild 2 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 19, Bild 3 von 3
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Start/Select Button Replacement: Schritt 20, Bild 1 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 20, Bild 2 von 3 PlayStation Vita Start/Select Button Replacement: Schritt 20, Bild 3 von 3
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
  21. PlayStation Vita Start/Select Button Replacement, Start/Select Button: Schritt 21, Bild 1 von 3 PlayStation Vita Start/Select Button Replacement, Start/Select Button: Schritt 21, Bild 2 von 3 PlayStation Vita Start/Select Button Replacement, Start/Select Button: Schritt 21, Bild 3 von 3
    • Using tweezers, peel the start/select button off the back case.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Brittany McCrigler
89.020 Reputation
131 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.234 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 47
Insgesamt: 7,540
