Zum Hauptinhalt wechseln
LG VX6100 Main Display Replacement
Was du brauchst
  1. LG VX6100 Main Display Replacement, Battery: Schritt 1, Bild 1 von 1
    • Open the battery casing by pressing the gray "PUSH" button. Slide the back of the casing downward.
    • Carefully remove the faulty battery from the back of the phone.
    • Inspect the battery port to ensure the battery is the issue. Ensure the four gold connecting prongs are intact and are pointing straight into the port.
  2. LG VX6100 Main Display Replacement: Schritt 3, Bild 1 von 1
    • Align the gold prongs with the gold plates on the bottom of the battery. Make sure "This Side Up" is visible
    • Push the battery flat against the back of the phone until it clicks into place.
    • Replace the back cover of the phone by sliding the casing down into place. Gently press the top until it clicks.
    • Charge the device and turn it on to confirm the issue is resolved.
  3. LG VX6100 Main Display Replacement, Front Case: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the four grey plugs using either tweezers or a push pin.
  4. LG VX6100 Main Display Replacement: Schritt 6, Bild 1 von 1
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
  5. LG VX6100 Main Display Replacement: Schritt 7, Bild 1 von 1
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
  6. LG VX6100 Main Display Replacement: Schritt 8, Bild 1 von 1
    • The case can now be removed and the interior of the front is accessible.
  7. LG VX6100 Main Display Replacement, Main Display: Schritt 9, Bild 1 von 2 LG VX6100 Main Display Replacement, Main Display: Schritt 9, Bild 2 von 2
    • Locate the solder on the side of the metal plate on the top half of the phone.
    • Place a piece of solder wick on top of the solder.
    • To desolder the connection, very carefully place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
    • The soldering iron will damage circuitry if held down for too long.
    • Cut off the used solder wick with pliers and repeat this step if any solder remains.
  8. LG VX6100 Main Display Replacement: Schritt 10, Bild 1 von 1
    • After the solder has been removed, pry off the camera assembly connection shield with the plastic opening tool.
  9. LG VX6100 Main Display Replacement: Schritt 11, Bild 1 von 2 LG VX6100 Main Display Replacement: Schritt 11, Bild 2 von 2
    • Remove the main display by lifting up the extruded white edge with your fingernail.
Abschluss
Ryan Bishop
1 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 12-39, Regan Spring 2012 Mitglied von Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 15
Insgesamt: 1,091
