Zum Hauptinhalt wechseln
Lenovo Yoga 720 Speaker Replacement
Was du brauchst
  1. Lenovo Yoga 720 Speaker Replacement, Bottom Cover: Schritt 1, Bild 1 von 3 Lenovo Yoga 720 Speaker Replacement, Bottom Cover: Schritt 1, Bild 2 von 3 Lenovo Yoga 720 Speaker Replacement, Bottom Cover: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    T5 Torx Screwdriver
    $5.49
    Kaufen
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Start by flipping the device over so that you see the screws.
    • Remove seven Torx T5 short screws.
    • Remove three Torx T5 long screws.
  2. Lenovo Yoga 720 Speaker Replacement: Schritt 2, Bild 1 von 3 Lenovo Yoga 720 Speaker Replacement: Schritt 2, Bild 2 von 3 Lenovo Yoga 720 Speaker Replacement: Schritt 2, Bild 3 von 3
    iFixit Opening Tool
    $1.99
    Kaufen
    • Starting from the USB port, use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the order shown by the arrows.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  3. Lenovo Yoga 720 Speaker Replacement: Schritt 3, Bild 1 von 3 Lenovo Yoga 720 Speaker Replacement: Schritt 3, Bild 2 von 3 Lenovo Yoga 720 Speaker Replacement: Schritt 3, Bild 3 von 3
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
  4. Lenovo Yoga 720 Speaker Replacement, Battery: Schritt 4, Bild 1 von 3 Lenovo Yoga 720 Speaker Replacement, Battery: Schritt 4, Bild 2 von 3 Lenovo Yoga 720 Speaker Replacement, Battery: Schritt 4, Bild 3 von 3
    JIS Driver Set
    $19.99
    Kaufen
    • This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
    • Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal.
    • Remove four J1 Philips screws.
    • Remove one J1 philips screw.
    • Do not mix these screws up. If you put the longer screw where the shorter screw belongs, you will damage the shield around the keyboard.
    • Lift the battery slightly using your plastic opening tool.
    • Do not lift the battery out all the way, as it is still connected to the motherboard.
    • Do NOT puncture or deform the battery or it may catch fire or even explode.
  5. Lenovo Yoga 720 Speaker Replacement: Schritt 5, Bild 1 von 3 Lenovo Yoga 720 Speaker Replacement: Schritt 5, Bild 2 von 3 Lenovo Yoga 720 Speaker Replacement: Schritt 5, Bild 3 von 3
    • Pull the battery towards you until the wire is accessible.
    • gently tug and wiggle on the wire until it pops out.
    • Remove the battery.
  6. Lenovo Yoga 720 Speaker Replacement, Speaker: Schritt 6, Bild 1 von 2 Lenovo Yoga 720 Speaker Replacement, Speaker: Schritt 6, Bild 2 von 2
    $3.99
    Kaufen
    • Disconnect the speakers.
  7. Lenovo Yoga 720 Speaker Replacement: Schritt 7, Bild 1 von 3 Lenovo Yoga 720 Speaker Replacement: Schritt 7, Bild 2 von 3 Lenovo Yoga 720 Speaker Replacement: Schritt 7, Bild 3 von 3
    • Remove the left speaker.
    • Remove the Adhesive.
    • Use this pull tab to remove it.
    • Remove the right speaker,
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Aiden
17.486 Reputation
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 1,795
