Zum Hauptinhalt wechseln
Toshiba Portege Z835-P330 Internal Cooling Fan Replacement
Was du brauchst
  1. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement, Internal Cooling Fan: Schritt 1, Bild 1 von 1
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: Schritt 2, Bild 1 von 1
    • Locate hidden screw found in the middle of back hardcover.
    • Here you will find a proprietary Japanese Screw Head.
    • Remove screw by using tool not provided by IFixit or by using the methods found here.
  3. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: Schritt 3, Bild 1 von 1
    • Peel off hard cover to expose interior of device
  4. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 1 mm screws using a Phillips #2 screwdriver.
  5. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: Schritt 5, Bild 1 von 1
    • Unplug the internal cooling fan by tugging gently on the wire attatched to the device's motherboard
  6. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: Schritt 6, Bild 1 von 1
    • Lift the internal cooling fan to remove the fan from the device
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 15
Insgesamt: 567
