Zum Hauptinhalt wechseln
Asus Chromebook C300SA-DS02 WiFi Card Replacement
Was du brauchst
  1. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Keyboard: Schritt 1, Bild 1 von 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 2, Bild 1 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 2, Bild 2 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 2, Bild 3 von 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 3, Bild 1 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 3, Bild 2 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 4, Bild 1 von 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Battery: Schritt 5, Bild 1 von 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement, Battery: Schritt 5, Bild 2 von 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 6, Bild 1 von 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 6, Bild 2 von 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 7, Bild 1 von 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: Schritt 8, Bild 1 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: Schritt 8, Bild 2 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: Schritt 8, Bild 3 von 3
    • Use the spudger to pop the black and white coaxial WiFi cables up from the WiFi card.
  9. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 9, Bild 1 von 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 9, Bild 2 von 2
    • Remove the one 3.6mm Phillips #0 screw from the WiFi card.
    • Pull and lift the WiFi card away from the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sarah Westberg
23.269 Reputation
70 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.290 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 424
