Zum Hauptinhalt wechseln
American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement
Was du brauchst
  1. American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement, Separate the handle: Schritt 1, Bild 1 von 1
    • Before you begin, make sure the sander is turned off and unplugged.
    • Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
  2. American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement: Schritt 2, Bild 1 von 3 American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement: Schritt 2, Bild 2 von 3 American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement: Schritt 2, Bild 3 von 3
    • The rear half of the enclosure is bolted to the handle support, so the front half will be removed first.
    • Pull the front half of the enclosure straight away from the rear half to separate the enclosure.
    • If the interlock assembly comes out with the front half of the enclosure, detach it and place it back into the rear half.
    • Remove the front half of the handle enclosure.
  3. American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement, Unplug the interlock assembly: Schritt 3, Bild 1 von 3 American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement, Unplug the interlock assembly: Schritt 3, Bild 2 von 3 American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement, Unplug the interlock assembly: Schritt 3, Bild 3 von 3
    • Pull the wires connected to the interlock assembly straight out of their connectors.
    • Keep track of where each wire connects on the interlock assembly.
  4. American Sanders EZSand Orbital Sander 07163A 2017 Interlock Assembly Replacement, Remove the interlock assembly: Schritt 4, Bild 1 von 1
    • After all wires are disconnected from the interlock assembly, remove the interlock assembly from the handle.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Adam O'Camb
196.940 Reputation
416 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 447
