Einleitung
Use this guide to remove or replace the interlock assembly in a Clarke Floor Sander 07163A 2017.
Was du brauchst
Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
Pull the front half of the enclosure straight away from the rear half to separate the enclosure.
Remove the front half of the handle enclosure.
Pull the wires connected to the interlock assembly straight out of their connectors.
After all wires are disconnected from the interlock assembly, remove the interlock assembly from the handle.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
