Zum Hauptinhalt wechseln
Xbox 360 E CD Drive Replacement
Was du brauchst
  1. Xbox 360 E CD Drive Replacement, Top Panel: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $2.99
    Kaufen
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Xbox 360 E CD Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Xbox 360 E CD Drive Replacement: Schritt 3, Bild 1 von 3 Xbox 360 E CD Drive Replacement: Schritt 3, Bild 2 von 3 Xbox 360 E CD Drive Replacement: Schritt 3, Bild 3 von 3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
  4. Xbox 360 E CD Drive Replacement, Wi-Fi Card: Schritt 4, Bild 1 von 1
    • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
  5. Xbox 360 E CD Drive Replacement: Schritt 5, Bild 1 von 2 Xbox 360 E CD Drive Replacement: Schritt 5, Bild 2 von 2
    • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
  6. Xbox 360 E CD Drive Replacement, Bottom Panel: Schritt 6, Bild 1 von 1
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
  7. Xbox 360 E CD Drive Replacement: Schritt 7, Bild 1 von 2 Xbox 360 E CD Drive Replacement: Schritt 7, Bild 2 von 2
    • Slide the spudger along the crevice to separate the grated face and the top body.
  8. Xbox 360 E CD Drive Replacement: Schritt 8, Bild 1 von 3 Xbox 360 E CD Drive Replacement: Schritt 8, Bild 2 von 3 Xbox 360 E CD Drive Replacement: Schritt 8, Bild 3 von 3
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
  9. Xbox 360 E CD Drive Replacement, Top Body: Schritt 9, Bild 1 von 2 Xbox 360 E CD Drive Replacement, Top Body: Schritt 9, Bild 2 von 2
    • Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
    • Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
  10. Xbox 360 E CD Drive Replacement, Bottom Body: Schritt 10, Bild 1 von 3 Xbox 360 E CD Drive Replacement, Bottom Body: Schritt 10, Bild 2 von 3 Xbox 360 E CD Drive Replacement, Bottom Body: Schritt 10, Bild 3 von 3
    • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
    • Lift the bottom body slightly away from the core at a 45 degree angle.
  11. Xbox 360 E CD Drive Replacement: Schritt 11, Bild 1 von 2 Xbox 360 E CD Drive Replacement: Schritt 11, Bild 2 von 2
    • Rotate the Xbox so you are now looking at the back of the device.
    • This step of disassembly requires the removal of the warranty sticker. This will void your warranty. Check the main page for a link to warranty information from Microsoft.
    • Remove the sticker from the back of the Xbox.
    • The sticker is not needed for reassembly.
  12. Xbox 360 E CD Drive Replacement: Schritt 12, Bild 1 von 3 Xbox 360 E CD Drive Replacement: Schritt 12, Bild 2 von 3 Xbox 360 E CD Drive Replacement: Schritt 12, Bild 3 von 3
    • Turn the Xbox to the left to locate the clip holding the body together.
    • With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
  13. Xbox 360 E CD Drive Replacement: Schritt 13, Bild 1 von 2 Xbox 360 E CD Drive Replacement: Schritt 13, Bild 2 von 2
    • Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
  14. Xbox 360 E CD Drive Replacement, CD Drive: Schritt 14, Bild 1 von 2 Xbox 360 E CD Drive Replacement, CD Drive: Schritt 14, Bild 2 von 2
    • Use your fingers to unplug the blue ribbon cable from the CD drive.
  15. Xbox 360 E CD Drive Replacement: Schritt 15, Bild 1 von 1
    Kaufen
    • Use tweezers to unplug the blue and pink wires.
  16. Xbox 360 E CD Drive Replacement: Schritt 16, Bild 1 von 1
    • Lift the front end of the CD drive and take it out.
Abschluss
22 weitere Nutzer:innen haben diese Anleitung absolviert.
George
545 Reputation
1 Anleitung geschrieben
Cal Poly, Team 2-11, Amido Winter 2014 Mitglied von Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Mitglieder
43 Anleitungen geschrieben
11 Kommentare
i wish the bottom cover magically came off like in step 9
sandjo - Antwort
screws are actually C1- C5 one is incorrectly labelled - C7 = C1 also in step 8.5 there are 3 clips holding back edge of bottom cover to top one. one on each end and one just to right of I/O area. can get 2 of them with a spudger (ends) and the middle one with a isesamo.
Andrew Boyd - Antwort
Several steps missing between 8 and 9
Freddie Parsons - Antwort
Like remove wifi adaptor.
william capewell -
There is some consistency errors in this guide. Step 9 seems to blast ahead beyond where we should be at this point of the guide.
Joe G. - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 42
Letzte 30 Tage: 158
Insgesamt: 21,230
