Zum Hauptinhalt wechseln
Motorola C290 Keypad Replacement
Was du brauchst
  1. Motorola C290 Keypad Replacement, Battery: Schritt 1, Bild 1 von 2 Motorola C290 Keypad Replacement, Battery: Schritt 1, Bild 2 von 2
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
  2. Motorola C290 Keypad Replacement: Schritt 2, Bild 1 von 2 Motorola C290 Keypad Replacement: Schritt 2, Bild 2 von 2
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
  3. Motorola C290 Keypad Replacement, Antenna: Schritt 3, Bild 1 von 3 Motorola C290 Keypad Replacement, Antenna: Schritt 3, Bild 2 von 3 Motorola C290 Keypad Replacement, Antenna: Schritt 3, Bild 3 von 3
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
  4. Motorola C290 Keypad Replacement: Schritt 4, Bild 1 von 2 Motorola C290 Keypad Replacement: Schritt 4, Bild 2 von 2
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
  5. Motorola C290 Keypad Replacement, Logic Board: Schritt 5, Bild 1 von 3 Motorola C290 Keypad Replacement, Logic Board: Schritt 5, Bild 2 von 3 Motorola C290 Keypad Replacement, Logic Board: Schritt 5, Bild 3 von 3
    • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
    • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
    • Note: This will reveal a screw. Five screws should now be visible.
    • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
  6. Motorola C290 Keypad Replacement: Schritt 6, Bild 1 von 2 Motorola C290 Keypad Replacement: Schritt 6, Bild 2 von 2
    • Insert the plastic opening tool in the groove at the top of the phone.
    • Rotate the tool to create an opening between the logic board cover and case.
  7. Motorola C290 Keypad Replacement: Schritt 7, Bild 1 von 2 Motorola C290 Keypad Replacement: Schritt 7, Bild 2 von 2
    • Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
    • Remove logic board cover and set aside.
  8. Motorola C290 Keypad Replacement: Schritt 8, Bild 1 von 1
    • Use the Spudger to detach the screen wire from the logic board.
  9. Motorola C290 Keypad Replacement: Schritt 9, Bild 1 von 3 Motorola C290 Keypad Replacement: Schritt 9, Bild 2 von 3 Motorola C290 Keypad Replacement: Schritt 9, Bild 3 von 3
    • Insert the Spudger into the slot on the top of the logic board.
    • Gently pry to loosen the top of the logic board.
    • Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
    • Grab the top of the logic board and pull at an angle to remove.
  10. Motorola C290 Keypad Replacement, Keypad: Schritt 10, Bild 1 von 1
    • Use your fingers to pull out the keypad.
    • Note: The keys and rubber backing are one piece.
Abschluss
Cal Poly, Team 24-28, Regan Spring 2010 Mitglied von Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 13
Insgesamt: 1,054
