Zum Hauptinhalt wechseln
Easyshare C813 Speaker Replacement
Was du brauchst
  1. Easyshare C813 Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Easyshare C813 Speaker Replacement: Schritt 2, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 2, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Easyshare C813 Speaker Replacement, Back Cover: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
  4. Easyshare C813 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Easyshare C813 Speaker Replacement: Schritt 5, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 5, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 5, Bild 3 von 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Easyshare C813 Speaker Replacement: Schritt 6, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 6, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 6, Bild 3 von 3
    Phillips #00 Screwdriver
    $5.49
    Kaufen
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Easyshare C813 Speaker Replacement: Schritt 7, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 7, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 7, Bild 3 von 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Easyshare C813 Speaker Replacement: Schritt 8, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 8, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 8, Bild 3 von 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Easyshare C813 Speaker Replacement, Front Cover: Schritt 9, Bild 1 von 2 Easyshare C813 Speaker Replacement, Front Cover: Schritt 9, Bild 2 von 2
    • Open the battery door.
  10. Easyshare C813 Speaker Replacement: Schritt 10, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 10, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 10, Bild 3 von 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Easyshare C813 Speaker Replacement: Schritt 11, Bild 1 von 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Easyshare C813 Speaker Replacement, LCD: Schritt 12, Bild 1 von 3 Easyshare C813 Speaker Replacement, LCD: Schritt 12, Bild 2 von 3 Easyshare C813 Speaker Replacement, LCD: Schritt 12, Bild 3 von 3
    • Once the front cover is removed, the battery door maybe closed for convenience.
    • Locate the exposed portion of the LCD screen.
    • Use a wedge to free the LCD screen from the medal housing.
    • Do not pull the screen away completely, it is still attached to the logic board via the yellow cable.
  13. Easyshare C813 Speaker Replacement: Schritt 13, Bild 1 von 1
    • Remove the screw at the upper right corner of the metal housing.
  14. Easyshare C813 Speaker Replacement: Schritt 14, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 14, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 14, Bild 3 von 3
    • Locate the 2 solder joints holding down the medal housing.
    • Remove the solder.
    • Place wick on solder.
    • Place solder iron on wick
    • The wick should be sandwiched between the iron and the solder.
  15. Easyshare C813 Speaker Replacement: Schritt 15, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 15, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 15, Bild 3 von 3
    • Peel back the black tape from the metal housing.
    • Lift the metal housing from the left so that it hinges on its right side.
    • The metal housing is still loosely attached on its right side.
  16. Easyshare C813 Speaker Replacement: Schritt 16, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 16, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 16, Bild 3 von 3
    • Locate black tab holding the LCD screen connector in the port.
    • Use wedge or fingernail to lift the black tab.
    • Pull the the LCD screen connector out of the port.
  17. Easyshare C813 Speaker Replacement, Logic Board: Schritt 17, Bild 1 von 1
    • Remove the medal housing from the logic board by carefully peeling the yellow tape off of the metal housing.
  18. Easyshare C813 Speaker Replacement: Schritt 18, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 18, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 18, Bild 3 von 3
    • Locate the 2 screws on the yellow tape.
    • Remove the 2 screws.
    • Remove the yellow tape.
  19. Easyshare C813 Speaker Replacement: Schritt 19, Bild 1 von 2 Easyshare C813 Speaker Replacement: Schritt 19, Bild 2 von 2
    • Locate the 2 solder joints near the shutter button.
    • Remove the solder on both joints with the wick and soldering iron in the same manner as Step 11.
  20. Easyshare C813 Speaker Replacement: Schritt 20, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 20, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 20, Bild 3 von 3
    • Turn the camera over.
    • Remove the screw holding the small green board.
    • Lift the small green board.
    • The small green board is still attached to the logic board via wires.
  21. Easyshare C813 Speaker Replacement: Schritt 21, Bild 1 von 1
    • Desolder the remaining 20 solder joints connecting the logic board to the camera.
  22. Easyshare C813 Speaker Replacement: Schritt 22, Bild 1 von 2 Easyshare C813 Speaker Replacement: Schritt 22, Bild 2 von 2
    • Locate the black tab holding the yellow cable in place.
    • Use a plastic opening tool or fingernail to lift the black tab.
    • Pull the yellow cable from the port.
  23. Easyshare C813 Speaker Replacement: Schritt 23, Bild 1 von 3 Easyshare C813 Speaker Replacement: Schritt 23, Bild 2 von 3 Easyshare C813 Speaker Replacement: Schritt 23, Bild 3 von 3
    • Use a plastic opening tool to lift the board from the camera.
    • Continue to remove the board completely.
  24. Easyshare C813 Speaker Replacement, Speaker: Schritt 24, Bild 1 von 1
    • Carefully pull the red and black wires located on the side of the camera connected to the speaker.
Abschluss
Cal Poly, Team 24-22, Regan Spring 2010 Mitglied von Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,804
